6v pos grd?
im new with this wiring, confusing.is the neg wiring going to everything the power source [amp drawing]?or is everything being feed from a positive charge from the body? i experienced a shock touching carb linkage when body was wet. if someone out there can explain it simple form ill appreciate itConfusedConfused
