Dual master cylinder conversion blocks
MN1154 replaces your single master cylinder distribution block to a dual this one fits `65 - `66.
Makes for a clean install if you want to add a `67 up dual master and staying drum.
If you added front disc brakes you will need MD2274 also
http://www.classicindustries.com/mopar/p...n1154.html
  Disc brake conversion part numbers 67440Dodge 6 19,179 01-25-15, 10:09 AM
