07-08-13, 10:44 PM
1966-1967 B-body. Auto or manual trans:
ATP 03153
ATP 03153
Speedometer Cables
07-08-13, 10:44 PM
ATP 03153
07-15-13, 03:55 PM
(This post was last modified: 07-15-13, 03:59 PM by thebankerstoy.)
Here are the original o.e.m. part numbers for the speedometer cables used for all of the 1966 and 1967 Dodge, Plymouth, Chrysler and Imperial models.
Richard 1966: Part number: 2661733 1966 Factory Parts Book section: 21-84-1 (separate sections for manual and automatic transmissions) Part Description: cable, with housing Transmission type: all manual and all automatic transmissions without auto pilot (cruise control) Applications: all A, B and C-Body models, all Imperial models without auto pilot (cruise control) Part number: 2661735 1966 Factory Parts Book section: 21-84-1 (separate sections for manual and automatic transmissions) Part Description: cable, with auto pilot (cruise control) Transmission type: all automatic transmissions with auto pilot (cruise control) Applications: all C-Body models, all Imperial models with auto pilot (cruise control( 1967: Part number: 2822713 1967 Factory Parts Book section: 21-84-1 (separate sections for manual and automatic transmissions) Part Description: cable, with housing Transmission type: all manual and all automatic transmissions without auto pilot (cruise control) Applications: most but not all A-Body models, all B-Body models, all C-Body models without auto pilot (cruise control) Part number: 2889783 1967 Factory Parts Book section: 21-84-1 (separate sections for manual and automatic transmissions) Part Description: cable with clip on ferrule Transmission type: all manual and automatic transmissions Applications: some A-Body Dart models Part number: 2822024 1967 Factory Parts Book section: 21-84-1 (separate sections for manual and automatic transmissions) Part Description: cable with housing Transmission type: all manual and all automatic transmissions without auto pilot (cruise control) Applications: all Dodge and Plymouth C-Body models, all Imperial models without auto pilot (cruise control) Part number: 2822714 1967 Factory Parts Book section: 21-84-1 (separate sections for manual and automatic transmissions) Part Description: cable, with auto pilot (cruise control) Transmission type: all automatic transmissions with auto pilot (cruise control) Applications: all Dodge and Plymouth C-Body models with auto pilot (cruise control) Part number: 2822716 1967 Factory Parts Book section: 21-84-1 (separate sections for manual and automatic transmissions) Part Description: cable, with auto pilot (cruise control) Transmission type: all automatic transmissions with auto pilot (cruise control) Applications: all Chrysler and Imperial models with auto pilot (cruise control)
07-15-13, 06:36 PM
Don't use a CA3004 from Pioneer it's about a foot too long for a 1967 440 4-speed, I ordered one just out of curiosity and found out.
If you wrap it around the drive shaft twice it would fit perfect.
07-15-13, 11:37 PM
67r/t4speeder Wrote:Don't use a CA3004 from Pioneer it's about a foot too long for a 1967 440 4-speed, I ordered one just out of curiosity and found out.Would that be the Italian drive shaft loop? LOL
07-16-13, 01:11 PM
Thanks guys, I just ordered one up for my convertible. I did an internet search on p/n 2661733 and got one from Atlas Obsolete because it comes with the firewall grommet and bracket.
07-16-13, 01:13 PM
theman440 Wrote:Thanks guys, I just ordered one up for my convertible. I did an internet search on p/n 2661733 and got one from Atlas Obsolete because it comes with the firewall grommet and bracket.Good find!!
07-16-13, 09:11 PM
theman440 Wrote:Thanks guys, I just ordered one up for my convertible. I did an internet search on p/n 2661733 and got one from Atlas Obsolete because it comes with the firewall grommet and bracket. Excellent Jeff. I also purchased an n.o.s. part number 2661733 speedometer cable assembly a few years ago for my 66 500 for the very same reasons that you did. Richard
07-21-13, 01:19 AM
Does anybody know if a 66 Coronet Automatic spedo cable will fit a 67 Coronet automatic? The one in my 67 looks looks like hamburger but still works. The car once was a race car and it looks like the old headers put off a lot of heat and cooked it. The one in my 66 parts car looks perfect.
07-21-13, 02:03 AM
hammond472 Wrote:Does anybody know if a 66 Coronet Automatic spedo cable will fit a 67 Coronet automatic? The one in my 67 looks looks like hamburger but still works. The car once was a race car and it looks like the old headers put off a lot of heat and cooked it. The one in my 66 parts car looks perfect. In my post above, you will see that the 1966 and 1967 Coronets use different factory part numbers for their speedometer cables and when I ran an application use search on the aftermarket part number ATP 03153 that Mike posted above, it told me that part number ATP 03153 was a perfect match for all 1967 Coronet models, no matter which engine, or transmission is in place, but that same part number was not a match for any 1966 Coronet model, regardless of the engine or transmission type, so I'm not sure what to tell you other than it looks like the 1966 and 1967 speedometer cables are somewhat different due to having different part numbers. If you have a good used 66 cable on hand already though, it won't cost you anything but some time to verify if the 66 cable will, or won't interchange on your 67. Richard
