guage issues
Hello All....
I have a 69 Coronet with non ralleye dash.....
I checked voltage limiter function at fuel tank sending unit with a test light.....I get a flashing light....
I checked voltage limiter function at temp sending unit with same light....I get nothing....
I placed a jumper wire from sending unit wire to ground.....gauge does not move....
I checked all wires behind dash....especially those leading to the round plug in center of instrument cluster....nothing seems amiss....
I checked wiring diagram....and the temp gauge and fuel gauge share feed from voltage limiter....
How is the cluster grounded? Is it through the dash itself? My headlights, instrument cluster lights, emergency flashers all work.
My steering wheel is not installed, so the harness connections to that are not hooked up....
Any thoughts?
thanks,
Mark
Last Post: Mark's 69
  A few issues I need help with. Jpr777 3 3,793 12-01-14, 02:18 AM
  Loose steering issues DannyHavs 10 8,264 06-12-14, 05:01 PM
Last Post: DannyHavs
  727 transmission issues hammond472 3 4,341 08-22-13, 01:08 AM
Last Post: hammond472
  Tail light issues. Avenger 2 3,601 05-28-13, 06:32 PM
  Wiring Issues markbob@ameritech.net 4 3,647 05-28-13, 02:40 PM
  Hot Rod mag issue 05/13: A Must Read on electrical issues Hibbing_Coronet_500 4 4,240 03-12-13, 10:13 AM
Last Post: jfreakofkorn
  Electrical issues cnmsales 8 6,430 03-10-13, 11:16 PM
Last Post: cnmsales
  1972 Coronet Starting Issues DreamRyder1963 9 6,463 02-17-13, 03:28 PM
