5.7 hemi build
A few months ago I bought this 2012 5.7, it was in a ram truck and had a miss on number 1 cylinder. Got it for $340. I had a pretty good idea it was going to be a wiped cam.
After tearing it down I wasn't surprised at what I found
I clean it a few times and pressure washed the block. And gave it a coat of motor coater race hemi orange
Of course pieces of the cam made their way through the motor, the bearings weren't in the best shape, the mains were worse than the rod, I replaced all of them. The crank wasn't to bad so I polished it by hand. The cam bearings were fine.
It had a miss alright!!
Amazing still running huh, I bet oil filter was a little over weight.
Having only ever worked on vintage mopar motors, some of the stuff inside is a little different- fractured connecting rods, they use a bolt but no nut. The pistons are very short with thin rings
Light weight parts
One piece rear main seal, what a great design
Why do they make so much HP? It's the heads of course, 330cfm on the intake side
New cam going in-
LockingĀ  out the cam phaser, this normally advances/retards the cam timing, you need to lock it out when you put a cam in with more lift/duration so you don't have piston to valve contact
There sure is allot going on these newer engines. Thanks Jeff.
It's amazing most dealers will only change out cam/lifters/intake (for some reason on a 5.7 you have to replace intake due to metal contamination in oil) when it gets wiped. And charge 10 grand for it when a reman long block from them is only 5k
  Hemi build 65rbdodge 17 60 10-06-23, 08:00 AM
  Build Numbers stonehengeheel 5 810 11-10-22, 08:52 PM
  1967 Coronet Hemi Value strangleholdracn 7 1,574 04-02-22, 08:03 PM
  Race Car new motor build has begun......... markz 14 28,593 02-22-20, 12:11 AM
  J Leno rolls over Hemi under glass crlush 3 4,437 05-21-16, 10:10 AM
  Quick story about HEMI'S Warhawkfight34 18 8,951 02-17-16, 08:41 PM
Last Post: 1969 Hemi RTs
  I'm so excited! My GTX Build............... markz 8 4,842 01-16-16, 01:05 PM
  1966 Hemi Coronet Survivor mozz at rpm 17 8,966 01-02-16, 06:24 PM
Last Post: Irores
  Getting Excited - GTX build markz 8 5,393 07-02-15, 03:05 PM
Last Post: Joe mama
  Hard life Hemi 67r/t4speeder 4 4,295 04-20-15, 06:50 PM
