bolt pattern power booster
hey i need to order a replacement booster i would like to make sure i get correct one. should the firewall bolt pattern be the same master cylinder. 3 3/8 x 3 3/8. i my can measure it from inside but its very thigh and awkward . i think i have a 7 inch dual booster from speedway motors . was on car when purchased. thanks
I won't be able to see if I still have the booster til the weekend, I'll measure for you if I got it still. I don't think I got rid of it during the Great Parts Purge To Piper
Sorry... I gave all my boosters away so couldn't measure.
If memory serves me right a friend did the Speedway conversion to is Challenger, and the bracket bolted right up to the existing manual brake mouting plate.
Easy way to check is to go to parts store, get a brake MC from anything from your car to a Diplomat, they all have same bolt pattern. I know cause mine is off a Dippy
Last Post: Mark's 69
  Bolt sizes Piper 2 3,346 06-06-16, 11:36 PM
Last Post: Piper
  Power brakes-vacuum hose to carb or intake? 67RTBlue 5 4,561 04-30-16, 01:33 PM
  Is the firewall different on a factory power brake car? 67RTBlue 2 3,379 04-07-16, 07:57 PM
  67 Coronet power window question Lipers1 8 5,324 10-11-15, 01:47 AM
  Power steering lines and pump Jpr777 7 4,436 09-25-15, 01:59 PM
  Power steering pump Lipers1 2 2,641 09-08-15, 10:39 AM
Last Post: Lipers1
