Long over due
I've owned ths car since 1989, you don't really notice them but for as long as I remember it had these gray colored stains on the paint surrounding most of the trim. I've tried many times to "clean" it off using different cleaners & waxes as well as using brushes - never had any luck. Well I decided to get serious -
Here is a pic of the left tailite - see the gray stain on the paint around the "C" shaped trim? Also you can see it above and below the trunk trim.
1206312067
To make thing easier I decided to remove the outer trunk trim, letters, lock cylinder and reverse lite assemblies. You can really see the stains with the parts removed.
120641206512066
What I ended up using to remove the stains, get ready to cringe . . . Acetone, wiping with a paper towel or using a toothbrush.
Here it is after cleaning off all the stains and waxing the pain - looks much better now. I cleaned and reinstalled the reverse housings, lock cyl & letters.
12068120691207012071
Next is to do some minor straitening of the upper & lower trim pieces before re-installing them - Does anybody know where I can get the plastic clips for the trunk trim?12065
Good job! Looks much better
i would try R/T specialties for the clips
  back after a long time rp23g7 14 7,582 12-20-17, 03:47 PM
Last Post: rp23g7
  A Long Winter's Nap OldSkool 4 3,750 11-11-15, 10:45 PM
  How long is a 67 Coronet? markz 2 3,167 02-03-15, 08:55 AM
