Fuel filler neck install - '55 Dodge
I saw a post for installing for a '69. Anyone had any experience with the '55 or '56? The bottom part of the neck is wedged between the frame and the body. Do you have to raise the body off the frame to remove? I can't figure out how to get it off. There isn't much room to negotiate the turns. That wouldn't be convenient to have to raise the body.
Sutton
Can you lower tank a bit?
The tank is off the car. This is a full off restoration, but the body was put back on the frame after painting. However, it looks like the filler tube should have been put between the body and frame before attaching body. I don't remember having to raise the body before taking it off.
  Fuel filler neck install Mark's 69 8 34,319 04-12-17, 11:07 AM
Last Post: David Lee
  318 Starter Install markbob@ameritech.net 7 7,408 05-15-13, 12:10 PM
