56 Gas Pedal Floor Mount
The gas pedal floor mount on my 1956 Coronet is rusted/falling apart and appears to be coming up when the pedal is pressed. I'm sure it's just a matter of time before it completely fails to hold the base of the pedal to the floor. Has anyone else had to deal with this? Should I seek an original equipment fix to this or remove the whole mechanism in favor of an aftermarket generic replacement?
Cormac417 Wrote:The gas pedal floor mount on my 1956 Coronet is rusted/falling apart and appears to be coming up when the pedal is pressed. I'm sure it's just a matter of time before it completely fails to hold the base of the pedal to the floor. Has anyone else had to deal with this? Should I seek an original equipment fix to this or remove the whole mechanism in favor of an aftermarket generic replacement?
Welcome! Would be easier to help with an answer if you posted pictures.
  Parking brake pedal-return spring?? 67RTBlue 3 4,116 07-27-15, 11:34 PM
  Gas pedal location DodgeT 14 8,069 09-11-14, 03:36 AM
Last Post: tgranthamfd
