Mystery switch
I have one of" those" questions maybe someone has the answer.while under my car measuring the brake lines i came across a line block right before the rear soft brake line that connects to the T on axle,that has a round switch ontop with 2 wires going up thru wheel well.What Is It?i ve checked my repair manual & the net, did not find.i know cant be a brake pressure switch ??
Well after some more research, is that the brake light switch? It works off pressure in the line?
Unplug it and jump it out and see if the brake lights come on.....
Good idea.worth a try.was hopeing someone was familiar with it
2 years later, yes it's the brake switch. sorry I haven't logged in for a while
I stopped fighting my inner demons. We're on the same side now.
roadworthy Wrote:2 years later, yes it's the brake switch. sorry I haven't logged in for a while
thanks I figured it out back then,havent been on for awhile either,LIFE getting in the way
