ride height
I got a 67 coronet and the passenger side sets about a inch and a half higher then the drivers side . what would cause this ? thanks . booboo
Front or rear? Is the car rusty around torsion Mounts? If OK it might be just adjustment off with torsion, or bad leaf spring.
Pics would help.
This reminds me. Does anyone have ride height specs? I feel like the front end is low at times and wonder if I should give the bars a few turns?
front , no rust . how do you adjust them ? thanks
Do have access to a service manual? I can explain it, but manual is much better.
67r/t4speeder Wrote:Do have access to a service manual? I can explain it, but manual is much better.
I have one but it's either missing "figure 1-15" or I'm blind! Honestly I've scanned that thing a few times and can't find any actual measurements and where they're made.
67RTBlue Wrote:I have one but it's either missing "figure 1-15" or I'm blind! Honestly I've scanned that thing a few times and can't find any actual measurements and where they're made.
I will check tomorrow also.
thanks guys . found it on youtube . 2 bolts , turn them one way and the car goes up . turn them the other way and the car goes down .
From a Motor Manual
My manual only goes back to 1968, but the specs for 68 to 74 are the same at 1&7/8" so I would guess a 67 is the same.
Jack up the car, magic marker a line on the socket for referance, crank each torsion bar up or down the same number of turns and see what you've got, maybe one's off a turn or so.
  My ride HiRez 1 11 10-07-23, 03:38 PM
  Changed oil, took a ride, lifter tick now. Red 67 3 3,206 09-12-17, 11:40 PM
  Seat height on a 67-feels low at times. 67RTBlue 5 3,733 04-28-17, 02:26 PM
  Let's go for a ride Piper 23 11,360 06-17-16, 12:15 AM
  Check it out. Retro radios for your ride. cnmsales 1 3,109 02-13-13, 05:12 PM
Last Post: 4264door
