383 with a/c pulleys to non a/c setup
Hi all,
question is I have a 67 440 with a/c.
i want to remove my a/c and Just have my p/steer, alt and water pump driven.
what different pulleys and etc do I need.
i don't have any other cars that I can access to copy or look at cheers.
I believe that you will need new water pump pulley (non/AC is bigger) and a new crank pulley. The AC cars had a water pump idler pulley - that goes away.
Need to find a picture of the belt routing. That may help you. Should have it in the factory service manual. I will check when I get a chance and post it if it does.
As far as which pulleys would be correct is beyond me - there are very many combos out there. I have a box full and just use what fits.
Mark is correct, the various accessory pulley locations and the belt routings are in the 1967 Factory Service Manual in the cooling section on page number 7-11. Due to copyright law restrictions I'm unable to post that page here, but if you need an authorized copy of the 1967 Coronet Factory Service Manual I can give you a reference to a company that is licensed by Chrysler that sells them. These manuals are offered in either a printed book format, or in a CD format as shown below. Purchasing a copy of this manual will be the best money you will spend on your car.
[Image: 1967%20Dodge%20Coronet%20Factory%20Servi...g~original]
Cheers
  Has anyone Added an in tank fuel pump For carby setup instead of standard electric Jpr777 5 3,272 10-08-15, 06:56 PM
Last Post: Drag-Net
