My R/T project
I started on the pass side floor, I noticed that it was rusted out when I was inspecting the car to take it to the track in San Antonio. Now the fun begins. I'm seeing more needs as I go deeper.
RT K_line Wrote:I started on the pass side floor, I noticed that it was rusted out when I was inspecting the car to take it to the track in San Antonio. Now the fun begins. I'm seeing more needs as I go deeper.
It's always more then you think!!!!!
Your R/T has been making and hiding rust secrets for 50 years now, so it won't give up all of those secrets easily or at one time. Wink
Are you going to make your own patch panels
Thanks for starting build thread Smile
Well I was going to cut what I needed from a 67 Belvedere im parting out but it was rusted in the same area, so I will be cutting the piece from the trunk lid that came with the car. It good thick metal. Here are some pictures of the headliner I did last month too. I'm thinking I might have a couple of chrome pieces to fill the sail panel joints.
Here are so pictures of the windshield install and rust repairs I made. I did this last summer.
67r/t4speeder Wrote:Are you going to make your own patch panels
Here's some pictures of the patch panel and spot welds. Started on the perimeter but ran out of wire. Still need to form the bottom edge though. It should look better after I grind down the welds and put some primer on it.
Your going for it on this car.
What are the plans for the hood?
67r/t4speeder Wrote:Your going for it on this car.
Do you mean the one I cut the patch panel from? I actually was thinking of using the frame structure and making a fiberglass lid. But now that I found an original one for 67 I'm not sure.
I just finished the floorboard patch. I think I did ok, I haven't really done much wire feed welding, just stick to this point. I'll have to grind down some of the bigger welds but it is a solid piece now. I beat on it with a big hammer and it sounds good and solid. Next to look at the driver side.
  Some assembly required.....New '65 Gasser project. Zeek 0 1,472 11-28-21, 11:35 PM
Last Post: Zeek
  Project "YANKEE EXPRESS" 1967 Coronet aslbow 19 11,431 11-04-15, 04:17 PM
Last Post: aslbow
