Engine rebuild on my '67 Coronet 500 - 383 4 BBL
#31
67r/t4speeder Wrote:Smile
That is the nicest NOT ONLY NO, BUT F**K NO I've ever gotten from someone!
Throw in a nicely machined flywheel and a case of Carlsberg ?no free tickets to some crazy rollercoaster accepted.
11 or 10.5?
Sounds like a conversation to be having in the pub talking measurements like that
i'm not sure what the last posts were about..
Got word from my machinist.
Block is perfect, no cracks. Crank journal 2 was always not quite to spec in roundness, they are machining it to specs. Will line bore it, then bore the cylinders to 030. We will use 010 cam bearings.
You will not have any problem with the HP manifolds as long as the pipes have the flange oriented right. I put a set on my 64 Fury with absolutely no problem. I ordered my exhaust pipes from TTI. They need the manifold casting numbers, and will make the pipes to fit. I was very happy with their system!
HI all,
OK major updates.
A heap of orders are now in!
This is what I have gone with:
Pistons - Sealed Power Speed Pro Forged alloy flat tops, with their Sealed Power File-fit plasma moly ring set.
Exhaust - 2.5" PYPES Stainless X-Pipe system, plus 2 of the Pypes Race Pro stainless mufflers. QTP electric cut outs, with the stainless dump pipes and stainless turn downs. Plus their wireless activation system.
Intake - Edelbrock RPM Performer with a Holley 750 Ultra DP (electric choke)
Heads - Don Garlits Alloy, with Bruce Toth gasket matching, cleaning the bowls then fully porting it. Then he will install the springs and valves to match my cam before he sends them.
Rocker assembly - Hughes 1.6 ratio Premium CNC'd Alloy roller rockers, with shims, spacers and grooved shafts.
Cam - Hughes Hydraulic Roller Whiplash, Comp cams nylon thrust button. Cam is a 3 bolt.
Timing gear - Progear double row true roller, hardened gears, 2 degree increments, 9 key way
So should be some interesting times ahead very soon.
560156025603
One of my heads being flow tested by Bruce Toth, from Toth performance. The heads are just roughed in, but Bruce cleaned one up and tested it to show me how we are going.
lift CFM Intake CFM Exhaust
.100 76.4 66.1
.200 153.5 114.5
.300 218.1 150.2
.400 254.9 177.4
.500 276.2 196.2
.600 286.2 208.2
He has a nice bench there
Yeah!
Bruce is good guy too.
  69 Coronet No Hidden VINs Macdon221 1 15,357 04-26-19, 12:34 PM
  Bumper Guards -66 Coronet MrCoronet 28 36,933 08-19-18, 03:58 PM
Last Post: MrCoronet
  Someone in here who owns a 66 HEMI coronet??? MrCoronet 1 18,240 06-29-17, 08:48 PM
  Pictures Wanted of Coronet 66-67 Convertibles and Hardtops MrCoronet 28 16,402 04-18-17, 07:25 AM
  66 coronet 440 4 door booker t jones 30 24,335 10-14-16, 06:06 PM
Last Post: Drag-Net
  No. of Coronet 500 Convertible -66 in Sweden MrCoronet 2 15,296 07-18-16, 07:37 PM
Last Post: j57little
  Correct Jack instruction decal to Coronet 66.. MrCoronet 42 15,193 04-11-16, 02:08 PM
  Tail panel Coronet 500- 66 ...always painted red between the taillights or full chrome? MrCoronet 9 7,319 03-16-16, 07:21 PM
Last Post: Jim 68cuda
  Hemi Coronet 66 - Tell me more about it... MrCoronet 2 4,396 02-25-16, 06:09 PM
  Need help decoding a 8 3/4 axle to a Coronet 500 convertible 66 MrCoronet 9 6,639 02-14-16, 08:30 PM
5 Guest(s)
