09-28-14, 01:16 PM
Hi All,
Does anyone know how to tell the difference between the 1968 coronet 383-4bbl that makes 330HP (VIN code G) and the 383-4bbl 335HP (VIN code H), just by looking at it? Access is limited. But here is what I know:
I was able to see the right lower side of the block (just above the oil pan). Definitely no flat spot with VIN or other numbers stamped on it.
Pad next to distributor has "D383" without "HP" next to it. Below that and to the right is the number "2".
Motor is Turquoise
Air cleaner is not double snorkel
Fender tag shows "62" as the engine code
Since the VIN is an "H" code and the fender tag and build sheet show a 62, I am trying to verify this is the original engine.
I am also not sure if all the research I am doing is yielding the wrong result and the original engine will not be "HP" and instead will just be the 383-4bbl 330HP version.
Any help would be appreciated
Motor is Turquoise
