stamped motor numbers
Is there any good information out there, on the stamped numbers on the head of a 318 I got for a spare?
PM318R 28031297
as best as I can tell, they are kind of hard to read!
Things I do know: 318ci, 1969 stamped on block, that's about it!
Thanks in advance.
Something doesn't look right. Try looking at this - http://www.rosevillemoparts.com/referenc...mbers2.php
Also there is nothing like your number in the Govier White Book. All casting & part numbers in the book have only 7 digits. That book covers the years 1962 - 1974. For 1968 thru 1971 the head casting number for a 318 head is 2843675 and the part number is 2843674. There are 5 valve cover bolt holes, the valve diameters are 1.78 and 1.50. They are open chamber heads.
Sorry had some things going on, haven't been on in a while, The numbers I mentioned are stamped on the front of the driver side head, they are not casted numbers?
Go to the listed website. It shows where to look for the numbers, and also what those numbers refer to. These are raised numbers that are part of the casting process. It sounds like what you are describing are numbers stamped into the head afterwards.
Yes these numbers are stamped into the head, the are not casting numbers. I was told the numbers could tell you more about the engine, than just the casting numbers?
mike1968rt Wrote:Go to the listed website. It shows where to look for the numbers, and also what those numbers refer to. These are raised numbers that are part of the casting process. It sounds like what you are describing are numbers stamped into the head afterwards.
From some in I found on the Dodge Charger site
PM=engine assembly plant Mound Road
318= displacement
R=regular fuel
2803=10,000 day calendar assembly date = Mar 29th, 1969
1297=engine sequence assembly number
10,000 day calendar http://www.extrememopars.com/chryslerdodgedatecodes.htm
Dodge Charger forum Page http://www.dodgecharger.com/forum/index....ic=32660.0
67wh41 Wrote:From some in I found on the Dodge Charger site
318= displacement
R=regular fuel
I see, not what I was looking for, but good information anyway. Thank you very much, maybe if I study a little more, I will get as good as you guys are! Thanks again.
  I have a 69 Coronet R/T 440 Motor- looking for car or owner of car. WS23L9G148774 Jakes 3 32,114 01-10-18, 07:10 PM
