replacement rims
my 50 coronet came with chrome rims.want to go back to stock look.orignal rims seem impossible to find.i read somewhere a ford rim will fit but forgot the year.anyone know off hand? thanks
Not knowing the bolt pattern of your 50 net for sure (I think it is 5x4.5"....), I suggest the following: measure the bolt spacing, offset and center bore for your rim and compare it. Here is a good link to a rock-crawling web resource that explains each of these measurements and how to get them (if you don't already know). There is also a handy chart for some common Furd, Dodge and Cheby rims.
Hope this information helps.
http://www.crawlpedia.com/bolt_patterns.htm
I have a set of 5, 4+ the spare that I removed from my 47 Desoto. I will not be using them, they have the clips to hold the baby moon style original hub caps. they are 5x4.5" shipping would be a killer though. any 5x4.5"(mopar and ford use this bolt pattern) should fit though.
hey, I bought the dodge full size covers already.should work on them.to get a idea how much are they?
hey, I bought the dodge full size covers already.should work on them.to get a idea how much are they?specs say 15x5 5bolt
thanks for the info
  Rear axle replacement for '58 dodge coronet acer 3 20 06-06-24, 02:15 PM
  The Replacement Motor 50Coronet 6 6,292 03-04-13, 10:45 PM
Last Post: 50Coronet
