08-21-16, 05:33 AM
Mopars & Missiles' Wrote:Good question, one that I was wondering about as well.
You state its a 440 and it has been "bored". You don't say "how much" and if a SONIC test was done prior to boring the block. Many blocks have excessive core shift from the factory and can't SAFELY be bored a large amount without first verifying wall thickness with a sonic test. So, what I'm trying to say is if it was bored without checking it, you may have had very thin cylinder thickness in that particular area which could then rupture easily. Especially with a ring that was expanding due to the ends butted up against each other with no place to go. Just a possibility.
If I remember well 0.30 or 0.40? Are those correct sizes to overbore? Done by a engine shop which has a good reputation over here. Not sure if they do sonic tests..
They will now decide to, not sure how to say this in English, put in a "bus" in the damaged cilinder. So the block can be re-used. Or start over with another 440 block. Which is like mine, from 1968..
