11-20-14, 12:58 PM
(This post was last modified: 11-20-14, 01:07 PM by thebankerstoy.)
Hello Zoran,
I have run a set of the original 1968-1969 HP big block exhaust manifolds on my 1966 Coronet 500 with both a low block 400 and it's current raised block 440 since 1989 when I bought the car and have had no clearance issues of any kind with the HP manifolds and my '66 sits a bit lower to the ground than stock ride height, so you should also have no issues running the Year One reproduction manifolds on your '67 as long as they are faithfully reproduced to factory specifications . Since you will be installing a completely new exhaust system from the engine back, the difference in the exhaust manifold flange angle also won't be an issue, because you will just build the new system to match the flange angles on your new manifolds right?
As I have mentioned in another thread here on the DCR concerning the use of these HP manifolds, my Coronet has run some high 12 second quarter mile passes in California's cooler weather and ran low 13's on a regular basis here in the hot weather in Arizona, so performance wise, I think they will meet your needs for the proposed engine build you're planning, as my 440 is putting out around 400 to 425 horsepower as well, so as long as the rest of your engine parts package compliment each other, (carb, intake manifold, cylinder heads, compression ratio, ect.) those manifolds will serve you well. Would I install them on a serious race car? No, but for any car like yours that is driven on the street most of the time, I wouldn't run anything else.
As far as fuel pumps, I will mention another part that I've been running on all of my Big and small block powered Mopars for many years now. That would be the Mopar Performance high performance mechanical fuel pump. It's available though any Mopar dealership's parts department that handles the Mopar Performance Parts line, or at any aftermarket parts supplier that sell the Mopar Performance Parts line. The big block fuel pump is sold under part #P4007039AB and fits all Mopar Hemi and big block engines including your 383. It's rated at 80 gph (gallons per hour) @ 8.7 psi and has worked extremely well on my cars both on the drag strip as well as on the street.
![[Image: MoparPerformancepartP4007039AB-bigb.jpg~original]](http://i146.photobucket.com/albums/r248/thebankerstoy/Parts%20Aftermarket%20And%20Mopar%20Performance/MoparPerformancepartP4007039AB-bigb.jpg~original)
To help keep contaminates out of that fuel pump, I also run one of the heavy duty Fram HPG-1 in-line fuel filters shown below. It is mounted towards the back of the car not far from the stock fuel tank. These Fram filters are easily found at many different outlets on-line and don't forget to purchase a spare filter element as well.
![[Image: FramHPG1highperformancefuelfilteran.jpg~original]](http://i146.photobucket.com/albums/r248/thebankerstoy/Parts%20Aftermarket%20And%20Mopar%20Performance/FramHPG1highperformancefuelfilteran.jpg~original)
![[Image: FramHPGC1replacementfuelfiltersforH.jpg~original]](http://i146.photobucket.com/albums/r248/thebankerstoy/Parts%20Aftermarket%20And%20Mopar%20Performance/FramHPGC1replacementfuelfiltersforH.jpg~original)
I've also upgraded my factory steel fuel lines from the stock 5/16" size, to the larger 3/8" size line to handle my 440's fuel delivery needs. You can either fabricate the new fuel lines yourself using your cars original factory steel fuel lines as a guide like I did, or there are several companies that sell complete fuel line kits in various sizes that you could purchase.
All of the above parts work extremely well together and have been in place on my '66 Coronet 500 since the early 90's, so I'm basing my thoughts and comments on many years of experience using those parts.
![[Image: My1966Coronet500-5-23-2013-5.jpg~original]](http://i146.photobucket.com/albums/r248/thebankerstoy/My%201966%20Dodge%20Coronet%20500%202%20door%20hardtop/My1966Coronet500-5-23-2013-5.jpg~original)
![[Image: Ricks1972DartSwinger-RichardTruesdellpho...g~original]](http://i146.photobucket.com/albums/r248/thebankerstoy/Ricks%201972%20Dart%20Swinger/Ricks1972DartSwinger-RichardTruesdellphoto-Jan200847.jpg~original)
![[Image: Ricks1972DartSwinger-RichardTruesdellpho...g~original]](http://i146.photobucket.com/albums/r248/thebankerstoy/Ricks%201972%20Dart%20Swinger/Ricks1972DartSwinger-RichardTruesdellphoto-Jan200848-1.jpg~original)
![[Image: 1972DartSwinger-restoredwithBEAUTIFULLeg...g~original]](http://i146.photobucket.com/albums/r248/thebankerstoy/Ricks%201972%20Dart%20Swinger/1972DartSwinger-restoredwithBEAUTIFULLegendaryAutoInteriorproducts.jpg~original)
![[Image: Ricks1972DartSwinger-enginecompartmentaf...g~original]](http://i146.photobucket.com/albums/r248/thebankerstoy/Ricks%201972%20Dart%20Swinger/Ricks1972DartSwinger-enginecompartmentafterrestoration-driversfrontsideview.jpg~original)
![[Image: Ricks1972DartSwinger-enginecompartmentaf...g~original]](http://i146.photobucket.com/albums/r248/thebankerstoy/Ricks%201972%20Dart%20Swinger/Ricks1972DartSwinger-enginecompartmentafterrestoration-frontview.jpg~original)
