New (to me) fiberglass hood and scoop. AAR brand
I like it a lot! Smile
Can you test fit those on anything else? I see they would work but if you ever wanted to remove them they might tear a bigger hole . Just an idea?
Those are the same barrel nuts they use to hold the "V8" on the fender. But that's a through hole. Might use them and some Right Stuff.
Yeah and they are designed for metal, not sure how they work on fiberglass myself.
I know I'd need something to expand just a little to stay in the hole but not so much that it over expands and cracks the hole open. I'm going to stop by Dexter Autobody in town and check with them. See what they recommend. I've seen a couple of nice cars getting done there. I'm sure they'd be able to help. I'll let you know what they say.
Didn't bother with the body shop visit. I just started with a tiny drill. It went through the outer panel then into a hollow area. So I open the holes up and used the barrel retainers I had and the went right in. A little tight too so I know they'll stay. The 383 emblems went easy too. Just put a little paint on the ends of the studs and held it up to mark it. Then drilled and used the nuts from the hood letter on the back side. Next thing will be the hood pins.
2255&d=1372788656[/IMG]Nice going
Looks great !
That really looks great, you're hitting the emblems spot on. At this point the hood pins should be a piece of cake for you.
Done. Except for the plates on top.
  Shifter and hood hinges for a 66 Bears-66 500 2 2,624 06-07-17, 02:00 PM
Last Post: crlush
  Fiberglass hood stand offs. Warhawkfight34 0 2,057 07-28-15, 08:15 AM
Last Post: Warhawkfight34
  1967 coronet front fiberglass bumper Stage III 2 3,462 07-01-15, 09:03 PM
  looking for 65 coronet hood trim spdmstr 1 2,580 03-27-15, 10:44 AM
Last Post: ckmopar500
  Will my rebuilt 440 fit with my stock 67 RT hood? my67RT 7 6,231 01-20-14, 06:48 PM
Last Post: Sedanman67
  1970 coronet r/t hood 70R/T 4 5,036 11-03-13, 11:52 AM
Last Post: 70R/T
  1967 Coronet Hood Trim Moulding Clips kildump 8 7,671 08-02-13, 11:13 AM
  Best place to buy hood scoops and side scoops for 70 coronet??? moparmusclecars 1 2,964 06-18-13, 02:33 PM
Last Post: jfreakofkorn
  hood trim value help 67r/t4speeder 17 11,326 06-03-13, 09:12 PM
  Finally got hood scoop on honcho 11 7,361 03-05-13, 11:32 PM
Last Post: mattsmopars
