Torque Thrust D Wheels
I looks really good and great Idea using the plastic pushpins because I know the original clips are nonexistent
I was also contemplating using 3m double-sided tape because I don't have the holes I was trying to avoid drilling any
67 R/T 440ci 4spd
[SIGPIC][/SIGPIC]
badmopar67 Wrote:I looks really good and great Idea using the plastic pushpins because I know the original clips are nonexistent
Thats not a bad idea either. They make adhesion promoter wipes that REALLY makes the tape stick. I only recommend applying it to the molding side. After that stuff is applied you don't get a chance to reposition! A technique to avoid lifting/repositioning is to leave the backing on except for one end where you peel back an inch or two. Line the molding up and then have a helper start to pull the backing as you keep it positioned. Careful not to break the backing as your pulling!
  Wheels for 66 Coronet sedan kalvie 1 7 5 hours ago
  70 R/T wheels rocketsama 13 6,345 09-01-17, 10:45 AM
  Torque Thrust D Wheels with pie crust cheaters. Hibbing_Coronet_500 0 2,398 12-17-14, 04:37 PM
  Wheels/Tires thread Lets discuss: Period Correct, Retro, All original, Pro Touring, etc... uncledon 7 5,083 05-27-14, 10:03 AM
Last Post: uncledon
  H code hemi wheels Rayh1967 10 7,647 03-27-14, 11:57 AM
  MAGNUM 500 WHEELS harold prentice 0 2,650 10-15-13, 09:30 PM
Last Post: harold prentice
  Wheel and tire fitment question for 17x9 wheels on a 65 craig440 0 2,697 04-04-13, 12:41 PM
Last Post: craig440
