11-18-14, 12:36 AM
I think Danny has some pretty good info on sizing your fuel system, If I'm not mistaken, he runs pretty fast on a 5/16 line, but you should confirm what he has to say too.
On the exhaust manifolds. The only difference on the left ones are the flange orientation. The pipe will match right up between the 67 and 68, but the flanges are at about 90 degrees apart.
If you want, I can go look at my 440 with hp manifolds, I would assume that if there is at least an inch under them, then you will have enough room. You are just dealing with a lower block height.
