Just curious what model# Headers those are? What kind of starter are you using? I just Ordered a complete Exhaust System from TTI for my 68R/T waiting on part's to arrive Thanks Ron
TTi part number 440-200 2" HEADERS -with 3.5" collectors
Tuff Stuff Starter, part number TFF-6084B
couple of things I ran into I could pass on to you
1.get the car high in the air, the tubes are long
2.you may need to turn the wheel from side to side to make clearance to get them in
3.I used a starter shim, it wasn't sitting flush until I did..first time I ever had to use one
4.the passenger side header in my case was harder to put on then the drivers, on the flange the second from front bolt needed to go in first, then slide the whole header back to bolt the rest in
