New (to me) fiberglass hood and scoop. AAR brand
FYI, The mold for that hood was made from a hood that I provided. I saw AAR at Englishtown many years ago and asked if they made a hood for '66/'67 Coronets. They said no, partly because they couldn't find a good core to make a mold from. I bought a hood at the show and gave it to them for making a mold.
What are you using for hood springs? I found some at Home Depot for a friends fiberglass hood that looked correct with low tension.
Always liked those. Looks good.
Well I drilled it for the molding. No problem with that but the original retainers/studs are not long enough. They need to be at least an inch long. The hood isn't that thick there but it is thicker than sheet metal. Here is a picture. The original on the right. The one on the left is from a piece of dash trim. It just pokes through. Not enough for a nut. Might have to make my own.
I got the hood springs with it. Todd said the came from AAR also.
Here is another picture of the underside.
Got the hood molding on. Had to modify the original retainers.
Nice work that looks sweet Big Grin
Next thing is the hood letters. No way they will go on like the original hood. I don't think the pegs will even go through. Going to have to use some other retainers. Like wall mollies or something. Then I think I might put "383 FOUR BARREL" emblems on the sides of the scoop.
Maybe use permatex right stuff on pins and push em through and a little more on whats underside, they wont go anywhere.
That's just it. They won't go through. It's going into a blind hole. I don't know if something like these would work.
  Shifter and hood hinges for a 66 Bears-66 500 2 2,624 06-07-17, 02:00 PM
Last Post: crlush
  Fiberglass hood stand offs. Warhawkfight34 0 2,057 07-28-15, 08:15 AM
Last Post: Warhawkfight34
  1967 coronet front fiberglass bumper Stage III 2 3,462 07-01-15, 09:03 PM
  looking for 65 coronet hood trim spdmstr 1 2,580 03-27-15, 10:44 AM
Last Post: ckmopar500
  Will my rebuilt 440 fit with my stock 67 RT hood? my67RT 7 6,231 01-20-14, 06:48 PM
Last Post: Sedanman67
  1970 coronet r/t hood 70R/T 4 5,036 11-03-13, 11:52 AM
Last Post: 70R/T
  1967 Coronet Hood Trim Moulding Clips kildump 8 7,671 08-02-13, 11:13 AM
  Best place to buy hood scoops and side scoops for 70 coronet??? moparmusclecars 1 2,964 06-18-13, 02:33 PM
Last Post: jfreakofkorn
  hood trim value help 67r/t4speeder 17 11,326 06-03-13, 09:12 PM
  Finally got hood scoop on honcho 11 7,361 03-05-13, 11:32 PM
Last Post: mattsmopars
