440 build questions. Intake,carb,torque converter? - Printable Version +- DodgeCoronet.com (https://dodgecoronet.com/forum) +-- Forum: Tech Discussion (https://dodgecoronet.com/forum/forumdisplay.php?fid=4) +--- Forum: Tech Q&A (https://dodgecoronet.com/forum/forumdisplay.php?fid=16) +--- Thread: 440 build questions. Intake,carb,torque converter? (/showthread.php?tid=2957) Pages:
1
2
440 build questions. Intake,carb,torque converter? - markz - 09-28-15 And the water pump scoring is no big deal. Install the biggest trans cooler you can........... 440 build questions. Intake,carb,torque converter? - 65rbdodge - 09-29-15 The performer rpm is a good intake but you will no be able to use the stock dual snorkel air cleaner, it will hit the hood. 440 build questions. Intake,carb,torque converter? - 67RTBlue - 09-29-15 65rbdodge Wrote:The performer rpm is a good intake but you will no be able to use the stock dual snorkel air cleaner, it will hit the hood. NEEDS to clear stock hood-options? Another question-block is stamped 12-27-65. Car had scheduled build of 9-22-66. Is that early of a cast normal? 440 build questions. Intake,carb,torque converter? - 67440Dodge - 09-29-15 Stranger things have happened, but the chance of that block being original to the car is pretty slim. 440 build questions. Intake,carb,torque converter? - 67RTBlue - 09-30-15 67440Dodge Wrote:Stranger things have happened, but the chance of that block being original to the car is pretty slim.Should have said casting date-have to look for assembly date. 440 build questions. Intake,carb,torque converter? - Racer Brown - 09-30-15 67RTBlue Wrote:Should have said casting date-have to look for assembly date.x2! 440 build questions. Intake,carb,torque converter? - 67RTBlue - 10-02-15 What should fuel line size be on a stock 440? 5/16" or 3/8" Years ago I must have ordered 3/8" tank to pump line as I have a brand new one. Can this be used-adapted down if stock is 5/16"? 440 build questions. Intake,carb,torque converter? - 67r/t4speeder - 10-02-15 5/16 is fine 440 build questions. Intake,carb,torque converter? - BBishere2 - 06-12-16 Holley Street Dominator Intake will give you more clearance for the stock air cleaner than the Performer RPM does, and maybe a few more HP. Think I would go with a 750 Speed Demon Carb w/ vacuum secondary and electric choke. You want your torque converter stall under your cruise RPM or you'll get slippage in the trans. Building up heat and burning up your transmission. Gear ratio and tire diameter are factors in figuring this out. Big block and heavy car will raise stall about 300 RPM over advertised range, so since it is mild. 2000-2400 range - I'd rebuild the 727 with a shift kit installed. Skip a reverse manual valve body, or you'll be shifting it at every light. |
