Screwed up fan switch wiring
I was rebuilding my instrument cluster on my 67 Coronet Wagon.
Not really rebuilding but repairing and replacing what was need, when I found the heater blower switch and connector was completely toasted.
I had taken pictures of everything as I went along so I would know where it all went after, but I screwed up on the heater blower connector and took out the three wires (light green dark green and tan) from the melted connector.
When I found a new connector I found that I had not taken a clear enough angle of the three wires as they are installed in the connector to the switch.
Do any of you guys have access to 67 blower switch wiring?
I have the service manual diagram but it does not show what wires go where on the switch.
anything would be great
thanks
Ac car?
Yes but it only has three wires to the switch, light green, dark green and tan.
in the service manual it shows four wires, the fourth being black.
it also doesn't show any detail as to what terminals the wires go to on the switch.
Mines got four wires non ac
I have a picture of that when I had my dash appart I will find it
I think I found what you need and its on page 24-11 in the manual, it shows the three prong switch on the A/C diagram.
try this
I agree with 67r/t on this! Mine is the same, but my picture isnt worth the upload.
Thank you very much that helps a ton, I found why I have three wires the tan wire is spliced farther ahead in the harness. Maybe it was a mid year change to split wire at plug instead of a splice, much faster to assemble at connector then to cut and solder in the wire harness.
Thanks again.
These are the kind of technical articles I really enjoy!
  Airtemp switch buttons sticking? 67r/t4speeder 9 29,850 11-15-18, 12:57 PM
  Best wiring replacement Dionisio -C- 28 13,988 06-07-17, 12:51 AM
Last Post: Dionisio -C-
  Turn Signal Wiring markz 5 5,795 10-12-16, 11:25 AM
Last Post: crlush
  Fan Switch and Other Wiring scottys67 13 8,139 08-29-16, 12:11 AM
Last Post: scottys67
  Neutral safety switch Avenger 15 10,001 08-11-16, 02:31 AM
Last Post: RT K_line
  '67 Factory tach and wiring questions. 67RTBlue 1 3,422 05-03-16, 11:38 AM
Last Post: JohnS
  Wiring nightmare DodgeT 3 3,651 09-21-15, 04:33 PM
  1967 Headlight Switch stonehengeheels 6 4,975 06-19-15, 01:24 AM
