1967 metallic red vinyl seat paint
Hello all. I found a new bench seat for my wagon, but it is off white. Have any of you experience with vinyl seat paint? Who's paint? and correct metallic red? Or a code that I may get mixed up here?
Thanks for the space to ask.
Oh another question. Do you have a source where I could get the original metallic red vinyl?
Jackson.
https://www.herbsparts.com/products.php?cat=826
I've used Herbs with a lot of success
Another excellent source for interior parts paint and upholstery is Legendary Auto Interiors. Their website link is below.
https://www.legendaryautointeriors.com/
Thanks for the replies. I will try Herbs, legendary said no paints.
Thanks again.
boydsdodge Wrote:Thanks for the replies. I will try Herbs, legendary said no paints.
Thanks again.
Quote:Oh another question. Do you have a source where I could get the original metallic red vinyl?
Jackson.
Legendary should be able to help you with this.
Not sure about the paint as they do mention this on their website.
Need Paint or Dye to Match Your Legendary Interior?
Check out our friends at [B]Kolor Korrect for custom matches to all of our vinyl products as well as all of your restoration color needs![/B]
Check Out Kolor Korrect
Here is my door, before and after with Herb's. I sprayed a square of vinyl and rubbed it around after it cured and it doesn't crack.
Mine's been painted black with SEM vinyl paint and have had no issues with cracking or fading..
  Looking for Paint Shop near Williamstown NJ 440net 5 428 03-03-23, 10:51 PM
Last Post: Piper
  1967 Coronet needs hood alignment 440net 1 1,483 10-15-21, 07:38 AM
  1967 Coronet Headlight surround fastners firepower 4 2,300 07-10-21, 12:39 AM
  convertible rear seat trim bike_guy123 3 25,604 06-30-18, 07:17 PM
Last Post: bike_guy123
  1967 Horn Relay Connector Housing TX67RT 1 19,032 10-06-17, 06:31 PM
  Pentastar location on passenger fender 1967 Dodge Coronet R/T chargerman71 3 4,936 06-22-17, 12:37 AM
  Seat belt bolts-Washers for the bolts and which ones get them?? 67RTBlue 4 5,123 09-03-16, 10:24 AM
  Paint code for Engine Turquoise 67RTBlue 3 4,721 01-12-16, 11:54 AM
  67 500 badge on trunk panel paint codes mocam8 3 4,336 06-09-15, 01:32 PM
  Primer and paint procedure the factory way? Hemigunnar 3 4,304 02-05-15, 12:27 PM
