New bullet for the "Brick"
#71
Nice Jeff , thanks for the up dates
Nice work Jeff. What are you using for black paint on the master cylinder stiffing plate? The sheen and solids look perfect.
ws27 Wrote:Nice work Jeff. What are you using for black paint on the master cylinder stiffing plate? The sheen and solids look perfect.
Rich,
It is Dupli-color Engine Low Gloss black DE1634
I love it - it has the perfect finish, I use it on any car part that needs to be black.
Thanks Jeff
Everything is looking great Jeff!
Thanks Joe!
Got some more parts in -
Custom solid roller from Hughes Engines, springs, cups, keepers and tool steel retainers.
11775
Shwing!!
Update,
Fabricated RT Rear brake adapter bracket installed and caliper mounted to check fitment - looks good. Now to do the other side, please excuse all the dirt & dust. I promise I'll clean it all up before final assembly.
11777
While I'm waiting on the block machine work I have been working on the rear end. After mocking up the left side caliper I shipped the axles back to Moser to get 'em drilled and tapped for 5/8 studs. Heavy car + lots of Power - just don't want to have problems.
11838
Locating and welding on the brake hose brackets.
1183911840
Bending up rt side hardline - I screwed up the left side so I need to get some more 3/16 line.
11841
