Progress on my 67 Coronet R/T
#71
67r/t4speeder Wrote:That is great, now you can research the dealership too. 2.94 gears? Wow freeway brawler
I tried to look up the dealership last night. Couldn't find anything about it. Does anyone know a good source of info on old dealerships?
If it ain't broke, fix it 'til it is...
Callingdrlove01 Wrote:I tried to look up the dealership last night. Couldn't find anything about it. Does anyone know a good source of info on old dealerships?
Check down in Dayton, maybe the place is still in buisness or just changed their name.
I requested the info for my car and they mis-read the ext color code so my "official" document shows the incorrect color - nice huh?
Try these guys -
http://www.hamtramck-historical.com/
Finally got the wheel arch patch panel. Not the greatest quality, but I can make it work. Doing some test fitting before it gets trimmed down. The body lines look like they will be pretty close and it does fit nicely to the outer wheel housing.
8996]8995]8994]
Lots of welding and grinding to do!
9015]9014]
Do yourself a favor and get the welds hotter. Those welds are too cold. Hotter weld will give a better weld and reduce grinding time.
markz Wrote:Do yourself a favor and get the welds hotter. Those welds are too cold. Hotter weld will give a better weld and reduce grinding time.
I agree, but I'm at the mercy of my welder. It seems different from day to day. One day it will make perfect welds, and the next it's just terrible. Hopefully when I start filling in it will be in a better mood!
What welder are you using?
markz Wrote:What welder are you using?
I have an old Century 110v might welder. It was my dad's and I ended up with it. On it's good days it will make a nice weld. Other times... not so much. I've restored several cars with it over the years. Too cheap to buy a new one.
  Last piece of the puzzle - 1966 Coronet convertible window trim CoVert66 3 1,044 09-23-22, 03:58 PM
  1967 Coronet needs hood alignment 440net 1 1,483 10-15-21, 07:38 AM
  1967 Coronet Headlight surround fastners firepower 4 2,300 07-10-21, 12:39 AM
Last Post: dodge55
Last Post: don99pablo
Last Post: David Lee
  '68 Coronet Taillights JimKueneman 0 3,352 10-01-16, 05:20 PM
Last Post: JimKueneman
