Progress on my 67 Coronet R/T
#51
About a millon holes drilled and welded up today.
8584]
If it ain't broke, fix it 'til it is...
You didn't run across a build sheet, did you??
Racer Brown Wrote:You didn't run across a build sheet, did you??
Unfortunately, no. I'm missing the build sheet and fender tag. Hopefully some day I can find one or the other.
Callingdrlove01 Wrote:Unfortunately, no. I'm missing the build sheet and fender tag. Hopefully some day I can find one or the other.
You can contact Chrysler Historical for a copy of the IBM card, that's almost as good as a build sheet, last phone# I had was, (313) 252-2902
Racer Brown Wrote:You can contact Chrysler Historical for a copy of the IBM card, that's almost as good as a build sheet, last phone# I had was, (313) 252-2902
I hadn't thought about that. The website says 67 is the last year they have records for. E-mailed build card copy is $35. I'll try it and see what they have. Thanks!
That's where I got my build card. Great work on the R/T!!
Just Wheels Wrote:That's where I got my build card. Great work on the R/T!!
Thanks! Is there enough information on the build card to get an accurate fender tag made?
I have not looked at the build card, just got it. I thought the fender tag had some other information, but I could be wrong.
You will have to have someone decode the IBM card, unless you can. You should get some additional info like the dealership, Zone and some other items.
Racer Brown Wrote:You will have to have someone decode the IBM card, unless you can. You should get some additional info like the dealership, Zone and some other items.
They claim they decode it for you. We'll see. I'm going to send away for it as soon as I get a printer that works. Tried to print out the form but apparently my printer is screwed up.
  Last piece of the puzzle - 1966 Coronet convertible window trim CoVert66 3 1,045 09-23-22, 03:58 PM
  1967 Coronet needs hood alignment 440net 1 1,484 10-15-21, 07:38 AM
Last Post: dodge55
Last Post: don99pablo
Last Post: David Lee
  '68 Coronet Taillights JimKueneman 0 3,352 10-01-16, 05:20 PM
Last Post: JimKueneman
