Threads: 49
Whats that little relay lookin thing on the firewall under the big plastic plug with all the wires coming from it ? A starter relay ? Thanks . BooBoo
Threads: 473
Starter relay if it has a positive cable from battery attached. Pics would help verify
Threads: 49
Anyone here with a 67 could verifie what it is . The 67s all came with the metal box with 4 prongs under the big plastic plug on the drivers firewall .
If the big plastic plug you are referring to is the bulk head connector. (lots of wires on three individual connectors) then it is the starter relay.
Threads: 49
Thank you sir . I was needing the correct name so I could order the rite part . Thanks . BooBoo
