Light and wiper switch removal 67 Coronet - Printable Version
+--- Thread: Light and wiper switch removal 67 Coronet (/showthread.php?tid=854)
Light and wiper switch removal 67 Coronet - JohnS - 04-23-13
Ok,
So I have taken the dash out to access the switches from above but for the life of me can`t see how they actualy come out. When I lay on my back and look in from behind it`s so restricted I can`t see a great deal. There is a very small metal button on the underside of the light switch which I pressed in and at the same time pulled the button on it`s shaft out but that`s about it.
Any help or pointers would be very much appreciated
Cheers
John
Ok,
Looks like I may have to be unscrewing the bezel at the front behind the knobs?
Light and wiper switch removal 67 Coronet - 67r/t4speeder - 04-23-13
JohnS Wrote:Ok,
Yes that is right the bezel screw's off. You got it
Light and wiper switch removal 67 Coronet - Copper67440 - 04-23-13
The head light switch bezel screws into the headlight switch. To take the bezel off you do need to remove the knob. Press that button and pull the knob. You may have to press hard and possibly wiggle and press then pull. But the knob will come out.
