Small coolant leak - Printable Version +- DodgeCoronet.com (https://dodgecoronet.com/forum) +-- Forum: Tech Discussion (https://dodgecoronet.com/forum/forumdisplay.php?fid=4) +--- Forum: Tech Q&A (https://dodgecoronet.com/forum/forumdisplay.php?fid=16) +--- Thread: Small coolant leak (/showthread.php?tid=729) |
Small coolant leak - Avenger - 04-06-13 My 318 poly is leaking coolant slightly.. It seems to be coming out of the bell housing area.. Its a very small amount.. I didnt have any problems with it at all last year no leak. After we put it on higher jackstands to do the brake lines it leaked 3 tiny drips on the floor.. What would cause this.. I dont have the means to drop the 727 or anything Small coolant leak - Avenger - 04-07-13 [SIZE=2]Upon closer inspection its wet around the oil filter and is running from there somewhere but the closest freeze plug is fine[/SIZE] Small coolant leak - ws27 - 04-07-13 Look up at the head gasket area. Also put a pressure tester on it to make it leak more. You might find that when hot nothing will come out. |
