Rear Wheel/Tire Size Advice - Printable Version
+--- Thread: Rear Wheel/Tire Size Advice (/showthread.php?tid=4143)
Rear Wheel/Tire Size Advice - MrV8JF - 05-14-23
Hi all
Looking for some advice on wheel sizes before I buy the AR Outlaw 1 wheels I want
So my car in the pic below on the rear has
15 x 8
3.75” Backspace
295/50/15 tires
The wheels I want I can either go for exactly the same as what’s on there , eg 15 x 8 with 3.75” BS and use my current tires
Or I’m tempted to go 15 x 10 which has a 4” BS, again using my current tires
I’m a bit confused though , so if you look at my tires they are really bulgy I guess because they are on 15 x 8’s , so if I fit 15 x 10’s I know it will make the tire less bulging but will it push the wheel out towards the arch more ? Or will it look similar to how it is now ? Eg the same distance between the edge of the tire and the arch as it is now ?
Currently there’s about 1.5” bulge on that tire, i seem to have plenty of room still
Ideally I want 15 x 10 but I don’t want to push it too far towards the arch lip
What would you do ? Stick with 15 x 8’s or go with the 15 x 10 ?
Alternatively I can go 275/60/15’s if need be
Please see pics below
Many thanks
[Image: 0-A73-CD69-D473-4-B2-D-8-DA6-E04-A8-FB80771.jpg]
[Image: 43-F307-CA-2496-4849-ADAE-D3-C85-A69-DA9-E.jpg]
[Image: 4-EDDC778-A9-D7-4-AB7-B3-E5-03-A76901-AB75.jpg]
[Image: 586-F38-D9-CDD5-4-B9-C-AFB7-6004-B20-BD77-E.jpg]
[Image: 5-DCC0-F9-A-65-FD-486-A-9-E61-B7-AE10-DC98-A0.jpg]
[Image: 711-ACF69-B136-4730-8-F8-C-E76-C280-B4-EE7.jpg]
[Image: 77-B8-A686-3827-477-C-8-F75-E07190-CD1-D3-F.jpg]
[Image: 84208-ABB-6382-40-C7-880-B-BCE5-C7-E1-E142.jpg]
[Image: ABBA2-AB7-1-D1-F-4688-AF22-C9157-AC8-EAAE.jpg]
[Image: C9-AC1047-4-C58-4-C05-827-E-0195077-A3-B6-A.jpg]
[Image: E7-F96-F36-1995-45-BC-98-F4-A904-EE9-A2871.jpg]
[Image: EEF279-CD-E2-C8-41-E0-9-A95-FAD610-B1-CFFC.jpg]
Rear Wheel/Tire Size Advice - 67440Dodge - 05-15-23
Welcome to the site from England! Which part are you from? I spend lot of time in Shirebrook area. Beautiful car, close to the same color as the Corsa I rented one time. Boy do they get pissy when you hit a pothole and scrape the tire.
I just got into this argument with the tire store last week when they screwed up my tire mounting. Going to a 10" wide rim will kick the tire out to about the bottom of the wheel well arch, the 1/4" extra backspacing won't help that much. Yes, it will reduce the "bulge", but the tire width will still be the same sidewall-sidewall (section width). Now if you are planning on changing rims and can find a set you like with say a 5" backspace, then you should be able to run the 295's without a problem. But if keeping that style rim, I'd go with the 275/60 tires myself. Just remember, you're speedo will read slower with the taller tire of the 275.
Here's the specs on the Cooper tires.
12524
