Returning member - Printable Version +- DodgeCoronet.com (https://dodgecoronet.com/forum) +-- Forum: Where The Fun Happens (https://dodgecoronet.com/forum/forumdisplay.php?fid=3) +--- Forum: New Members (https://dodgecoronet.com/forum/forumdisplay.php?fid=10) +--- Thread: Returning member (/showthread.php?tid=3928) |
Returning member - MoparRich - 04-05-20 Been a member since 2014 but mainly as a lurker. I'm active on FBBO and FABO. Bought a 69 Coronet 500 off of Ebay in September 2013. After delivery I checked everything out - fluids, brakes, ignition. But not the lug nuts. After only three weeks of ownership I was taking a test drive after swapping in a Pertronix distributor and the left front lug nuts backed off, wheel went up into the fender before the car came to a skidding halt. Fortunately I had slowed down to about 20 mph when the wheel let loose. Long story short, spent the next 2 1/2 years restoring the car in my garage to wind up with the car you see today. Originally came with a 383 2V, a PO swapped in a 70's 440. The engine has been rebuilt with its original steel crank, Hughes Engines hyd FT cam and valve train, ported Stealth heads, Eddy dp intake, FiTech efi with Tanks Inc. in-tank pump, Dougs headers. Added a Classic Air unit. Glen-Ray rad with clutch fan. Rebuilt trans has a 3000 stall Dynamics converter and TransGo shift kit back to a 3.55 SG 8 3/4. Front disc brake conversion, rebuilt front suspension with Firm Feel Stage III p/s box. Sub-frame connectors, super stock rear springs with pinion snubber, Bilsteins on all four corners. Interior was changed from saddle tan to black. Restored the dash, MAD electric ammeter by-pass with voltmeter, RetroSound radio. Fat Mat on the floors, roof, and inner door skins. Stock seats were bolstered in front and finished with black vinyl with grey suede inserts; kept the Coronet medallion trim. Body was painted in FCA Toxic Orange (OEM color on 2013 Challengers). Wheels/tires are 15 x 8 Magnums with 245/60/15 BFGs in front and 15 x 10 Magnums with 295/50/15 BFGs out back. Car has been back on the road since Spring 2016 but since then I've been sorting through all kinds of issues: FiTech (don't get me started), hot start, braking. It's only been the last 6 months or so that the car can be described as reliable. It gets driven about 2,000 miles a year, sharing time with my '68 Dart and '16 Challenger. It's fast, loud and a blast to drive. 120281202712026 Returning member - 65rbdodge - 04-05-20 Nice car! Sounds like you’ve put a lot of time and money into it Returning member - MoparRich - 04-05-20 Yes to both. I bought a front clip after the accident and when I removed the damaged fender there was a lot of rust - no rot but rust everywhere. I started peeling back layers finding more and more and the next thing i knew i was in the middle of a restoration. Returning member - 67r/t4speeder - 04-06-20 Welcome back Rich Thanks for the pics |
