56 Gas Pedal Floor Mount - Printable Version
+--- Forum: Coronet Restoration/Paint Shop/Body Shop (https://dodgecoronet.com/forum/forumdisplay.php?fid=17)
+--- Thread: 56 Gas Pedal Floor Mount (/showthread.php?tid=3615)
56 Gas Pedal Floor Mount - Cormac417 - 06-04-17
The gas pedal floor mount on my 1956 Coronet is rusted/falling apart and appears to be coming up when the pedal is pressed. I'm sure it's just a matter of time before it completely fails to hold the base of the pedal to the floor. Has anyone else had to deal with this? Should I seek an original equipment fix to this or remove the whole mechanism in favor of an aftermarket generic replacement?
56 Gas Pedal Floor Mount - markz - 06-06-17
Cormac417 Wrote:The gas pedal floor mount on my 1956 Coronet is rusted/falling apart and appears to be coming up when the pedal is pressed. I'm sure it's just a matter of time before it completely fails to hold the base of the pedal to the floor. Has anyone else had to deal with this? Should I seek an original equipment fix to this or remove the whole mechanism in favor of an aftermarket generic replacement?
Welcome! Would be easier to help with an answer if you posted pictures.
