Mystery switch - Printable Version
+--- Forum: The Early Years (https://dodgecoronet.com/forum/forumdisplay.php?fid=27)
+--- Thread: Mystery switch (/showthread.php?tid=3587)
Mystery switch - 50net - 04-25-17
I have one of" those" questions maybe someone has the answer.while under my car measuring the brake lines i came across a line block right before the rear soft brake line that connects to the T on axle,that has a round switch ontop with 2 wires going up thru wheel well.What Is It?i ve checked my repair manual & the net, did not find.i know cant be a brake pressure switch ??
Well after some more research, is that the brake light switch? It works off pressure in the line?
Mystery switch - Drag-Net - 04-26-17
Unplug it and jump it out and see if the brake lights come on.....
Mystery switch - 50net - 04-26-17
Good idea.worth a try.was hopeing someone was familiar with it
Mystery switch - roadworthy - 04-27-19
2 years later, yes it's the brake switch. sorry I haven't logged in for a while
Mystery switch - 50net - 07-23-19
roadworthy Wrote:2 years later, yes it's the brake switch. sorry I haven't logged in for a while
thanks I figured it out back then,havent been on for awhile either,LIFE getting in the way
