Back up lights - Printable Version +- DodgeCoronet.com (https://dodgecoronet.com/forum) +-- Forum: Where The Fun Happens (https://dodgecoronet.com/forum/forumdisplay.php?fid=3) +--- Forum: General Discussion (https://dodgecoronet.com/forum/forumdisplay.php?fid=12) +--- Thread: Back up lights (/showthread.php?tid=3442) |
Back up lights - Red 67 - 11-07-16 Hi everyone. I was hoping to get some direction with my inop back up lights. When I put it in reverse they flash but that's it. Is there a switch with an adjustment in the shifter mechanism or do you think it's just a bum n/s switch? Back up lights - 67RTBlue - 11-07-16 From memory when I put ours together the switch mounted on the shifter under the console is adjustable. A sloppy shifter linkage will make this tricky. I adjusted ours to the center of the "slop". Put the car in reverse and have someone watch the lamps as you adjust it. Might try cleaning the switch with electronics spray cleaner too. Back up lights - Red 67 - 11-08-16 Ok will do thanks Blue. Back up lights - Red 67 - 11-12-16 That did the trick, thanks! Back up lights - 67RTBlue - 11-12-16 Cool man! |
