Heater control cables-routing question - Printable Version +- DodgeCoronet.com (https://dodgecoronet.com/forum) +-- Forum: Tech Discussion (https://dodgecoronet.com/forum/forumdisplay.php?fid=4) +--- Forum: Tech Q&A (https://dodgecoronet.com/forum/forumdisplay.php?fid=16) +--- Thread: Heater control cables-routing question (/showthread.php?tid=3306) |
Heater control cables-routing question - 67RTBlue - 06-16-16 When installing the dash one of the cables (temp control) that comes off the controls rubs on the wiper linkage arm under the dash. I currently have it routed under the arm. The angle at which it comes off the controls on the dash its pushing it up onto the arm. I'm wondering if it is supposed to go above the linkage which might allow it to not rub the way it does now? Can anyone look up under the dash and see theirs? The cable with the red band in the pic.8547] Heater control cables-routing question - ws27 - 06-16-16 There supposed to be a clip that holds it down on the top of the heater box. Can you sneak a tie wrap on it, or are you going for original? Heater control cables-routing question - 67RTBlue - 06-16-16 ws27 Wrote:There supposed to be a clip that holds it down on the top of the heater box. Can you sneak a tie wrap on it, or are you going for original? This is the control that lays on top of the box not on the front. I know the clip thing that is riveted to the heater box I have. I popped the linkage off and dropped it below the cable and it seems right like this and no longer rubs on the cable. Heater control cables-routing question - 67r/t4speeder - 06-16-16 Looked at both of my cars and both cables are on top and cables rub linkage barely Heater control cables-routing question - 67RTBlue - 06-16-16 I popped the wiper linkage and its better that way. Just didn't think the cable would route "through" the linkage assy. |
