Adjust the carburator ..on a 2v 318 Poly from 1966 (all original) - Printable Version
+--- Forum: The Muscle Car Years 1965-1970 (https://dodgecoronet.com/forum/forumdisplay.php?fid=28)
+--- Thread: Adjust the carburator ..on a 2v 318 Poly from 1966 (all original) (/showthread.php?tid=3267)
Adjust the carburator ..on a 2v 318 Poly from 1966 (all original) - MrCoronet - 05-14-16
Hi Everybody!
Someone out there with a good description/pictures?
Think my 500 running a little rich..
Have a good weekend
Regards
Anders
Adjust the carburator ..on a 2v 318 Poly from 1966 (all original) - Dave Wallace - 05-24-16
I had to play with mine all the time yrs ago, first make sure the distriutor timing is correct, good new fuel, and use a vacuum gauge connected to the front of the 2 middle screws and slowly adjust back and forth till you get the most vacuum and the needle doesnt bounce around
Adjust the carburator ..on a 2v 318 Poly from 1966 (all original) - MrCoronet - 05-24-16
Hi Dave!
Jepp, must check the timing...first
Thanks a lot for your answer
Regards
Anders
