Needed: Carter 4329S rebuild kit (67 R/T) - Printable Version +- DodgeCoronet.com (https://dodgecoronet.com/forum) +-- Forum: Tech Discussion (https://dodgecoronet.com/forum/forumdisplay.php?fid=4) +--- Forum: Tech Q&A (https://dodgecoronet.com/forum/forumdisplay.php?fid=16) +--- Thread: Needed: Carter 4329S rebuild kit (67 R/T) (/showthread.php?tid=3248) |
Needed: Carter 4329S rebuild kit (67 R/T) - David Lee - 05-03-16 From what I gather, that particular carb went on the R/T with the AT and AC options. Mine is able to run with the idle bleeds closed, and not a lot of throttle stop added. Very rich at any setting. A guy in town with a good reputation says he can rebuild them, and does, but for $250 min. I'd like to do it myself. (Edit, this part number is on the tag on the carb and the one the book specifies) Does anyone know of a good source for quality parts for these? Thanks in advance. Needed: Carter 4329S rebuild kit (67 R/T) - David Lee - 05-04-16 Would any old AFB kit work? Needed: Carter 4329S rebuild kit (67 R/T) - ws27 - 05-04-16 It should, you can't find a Hygrade kit for it? Needed: Carter 4329S rebuild kit (67 R/T) - David Lee - 05-04-16 ws27 Wrote:It should, you can't find a Hygrade kit for it? Thanks. I was looking for a reputable kit. I'll try that Hygrade 357B. Rationale- it's been almost 20 years since the carb was rebuilt. Ambient temperature here is often well over 100F, so I'd installed an aluminum plate at the carb base with a phenolic spacer to prevent vapor locking. (Hard hot starts) It did help, but I suspect I might have caused a leak there. I'll check that, but since the carb will be removed, might as well rebuild it. Thanks again. I am new at this and discovering there is a lot I don't know about...everything. (learning curve) |
