Where do these bolts go? - Printable Version
+--- Thread: Where do these bolts go? (/showthread.php?tid=3064)
Where do these bolts go? - 67RTBlue - 12-30-15
Found these in a box with a bunch of the engine bolts and I can't figure out where they came from. They have very fine threads and a couple have traces of turquoise engine color paint. There are 4 and they are 9/16"
Where do these bolts go? - theman440 - 12-30-15
Those are flex plate bolts.
Where do these bolts go? - 65rbdodge - 12-30-15
theman440 Wrote:Those are flex plate bolts.
yup
Ahhhh
Thanks guys!
Where do these bolts go? - Racer Brown - 12-30-15
X3!
Ok I should start a "Where does this go thread"
This bracket? The slot is too big for a spark plug wire.
7645]
Where do these bolts go? - Mopars & Missiles - 12-30-15
67RTBlue Wrote:Ok I should start a "Where does this go thread"
7645]
This is the bracket for the #8 spark plug wire on a BB. The slot is missing the plastic insert that holds the plug wire firmly in place. I think I have a pic of this bracket installed. It bolts to the very back exhaust manifold stud on the passenger side. On the pic showing the transmission/engine assy, it is just visible next to the filler tube for the transmission. The other pic, it is just visible on the extreme left side of the picture, the plastic insert that you are missing is partially cut off in the picture.
7646]7647]
Here is the part with description that you have.
http://www.megapartsusa.com/proddetail.asp?prod=101%2DPWBJ
Again! Thanks! I was hoping to use the factory wire holders but my dad bought headers (Hooker Super Comp) for this car 15 years ago and wants to use them. These interfere in a few spots. What other unforeseen problems will I run into using headers? Will a factory wite set work with them? I'm trying to stay stock looking as possible with everything. That engine in the pics is BEAUTIFUL! Love a bone stock look. Again I'm trying to pull off that look as closely as possible. Saving all the original stuff for the day anyone wants to change it back of course.
