Electroinc Ignition - Printable Version
+--- Forum: Modernize your Coronet (https://dodgecoronet.com/forum/forumdisplay.php?fid=21)
+--- Thread: Electroinc Ignition (/showthread.php?tid=2982)
Pages: 1 2
Electroinc Ignition - TX67RT - 10-08-15
Greetings - Is there an electronic ignition system available that is absolutely undetectable visually? My R/T is absolutely original, and I don't want anything to mar that appearance. However, I'd like to get a little more reliability and performance from electronic ignition. I absolutely don't want the external Mopar control module, so the typical route is out for me.
I thought I remembered a system out there which was undetectable without removing the distributor cap. I don't want any extra wires coming out of the distributor, or any other externally mounted components. If there isn't anything like this available, I'll just keep my breaker points. I kind of like the ritual of setting dwell and timing anyway... Big Grin
Thanks!
JD
Electroinc Ignition - ws27 - 10-09-15
A lot of people like Pertronix.
Personally, I use Mopar factory el dist., a wiring harness with the extra wires built in, and a pig tail long enough to hide the box. The only thing you see is the two wire dist, but you really have to look for it.
Electroinc Ignition - JohnS - 10-09-15
https://www.customwiresets.com/product.php?productid=16287&cat=252&page=1
Pretty much as above with ws27, but this is what I have fitted with the stock cap option.
Electroinc Ignition - TX67RT - 10-10-15
Thanks for the input guys. But, both of these options are too visible for me. I was hoping that there was something that just replaced the breaker points inside the cap, and that's it. Looks like I better not throw away my dwell meter just yet...
Thanks,
JD
Electroinc Ignition - Racer Brown - 10-10-15
Doesn't Prolex or some name like that have a setup?
Electroinc Ignition - 67r/t4speeder - 10-10-15
Racer Brown Wrote:Doesn't Prolex or some name like that have a setup?
I think Prolex is a dietary supplement with common side effects like : Violent bowel movements, sudden bleeding from the eyes, almost always loos of finger nails Steve
Electroinc Ignition - markz - 10-10-15
Pertronix Module goes in distributor otherwise stock looking.
http://www.summitracing.com/parts/pnx-1381a/overview/year/1969/make/plymouth/model/roadrunner
http://www.summitracing.com/parts/pnx-91381a/overview/year/1969/make/plymouth/model/roadrunner
Electroinc Ignition - Racer Brown - 10-11-15
67r/t4speeder Wrote:I think Prolex is a dietary supplement with common side effects like : Violent bowel movements, sudden bleeding from the eyes, almost always loos of finger nails Steve
OMG, you scared me!
Electroinc Ignition - TX67RT - 10-14-15
markz Wrote:Pertronix Module goes in distributor otherwise stock looking.
Thanks, that looks very interesting. Looks like there are two wires exiting the distributor, which won't look quite right. Wonder if there's a way to ground one wire inside the distributor so only one shows. I suppose it wouldn't be too bad to have two wires; I could shrink-tube them together to disguise them, I guess. Will this work with an OEM coil? One more question; you have links to two versions. Other than the $40 price difference, what's the difference between them. I'm assuming that for an otherwise stock set-up, the "cheap" one would work fine. No big deal to pop for the higher-priced one if there's a real benefit.
Thanks!
JD
Electroinc Ignition - TekHousE - 10-19-15
I run pertronix. I highly recommend it. I kept the stock ballast resistor on the firewall, but I bypassed it behind the resistor. SO no one really sees that I have electronic ignition without poking around closely.
