Has anyone Added an in tank fuel pump For carby setup instead of standard electric - Printable Version +- DodgeCoronet.com (https://dodgecoronet.com/forum) +-- Forum: Tech Discussion (https://dodgecoronet.com/forum/forumdisplay.php?fid=4) +--- Forum: Tech Q&A (https://dodgecoronet.com/forum/forumdisplay.php?fid=16) +--- Thread: Has anyone Added an in tank fuel pump For carby setup instead of standard electric (/showthread.php?tid=2978) |
Has anyone Added an in tank fuel pump For carby setup instead of standard electric - Jpr777 - 10-07-15 Has any one ran an in tank fuel pump in their cars to their carbys. the issue I have is that I cannot have the holley electric fuel pump gravity fed as the fuel tank pick up is on top of the tank. so I was wondering what have people done with this situation. cheers Has anyone Added an in tank fuel pump For carby setup instead of standard electric - 67440Dodge - 10-07-15 Almost all in tank fuel pumps are designed for EFI systems, so you need to do some special configuration with regulators to get the pressure down that a carb can use. Most add a sump to the bottom of the tank and run the fuel lines off that. Has anyone Added an in tank fuel pump For carby setup instead of standard electric - Drag-Net - 10-07-15 My holley elec. pump is on the inside of my pass. side frame rail down low by the front spring hanger, using a stock 3/8 pick up / sending unit in the tank. It's worked perfectly fine for the last 15 years. It is noisy........ Has anyone Added an in tank fuel pump For carby setup instead of standard electric - Jpr777 - 10-08-15 interesting would you be able to provide a photo for me please Drag-Net Wrote:My holley elec. pump is on the inside of my pass. side frame rail down low by the front spring hanger, using a stock 3/8 pick up / sending unit in the tank. Has anyone Added an in tank fuel pump For carby setup instead of standard electric - markz - 10-08-15 This is what I did. It probably will be for sale at some time................ 7276] Has anyone Added an in tank fuel pump For carby setup instead of standard electric - Drag-Net - 10-08-15 I hope this is helpful. |
