No nubs for body trim - Printable Version +- DodgeCoronet.com (https://dodgecoronet.com/forum) +-- Forum: Tech Discussion (https://dodgecoronet.com/forum/forumdisplay.php?fid=4) +--- Forum: Coronet Restoration/Paint Shop/Body Shop (https://dodgecoronet.com/forum/forumdisplay.php?fid=17) +--- Thread: No nubs for body trim (/showthread.php?tid=246) |
No nubs for body trim - BooBoo - 01-16-13 I got a 67 . One side has body trim and the other side dont have any exept for the piece that goes around the front tire . The side without dont even have any of those little nubs that help hold the trim on . So how would you fix this ? Take the other side trim off , grind the nubs off and leave it like that ? Is there some kind of kit you can buy that would screw to the side of the car with the nubs on it ? What about the aftermarket trim sold at the local parts store with the adhesive backing . I,m not worried about the car being original , I just want it to look nice . What would you guys do . Thanks . BooBoo No nubs for body trim - ws27 - 01-16-13 You can hold or trim clips with screws of pop rivets. Some of the body side mouldings have threaded studs that pass through the body panel and secure with a nut. Check out R/T Specialties for the clips. No nubs for body trim - BooBoo - 01-16-13 Yea , that makes sense . Thanks |
