Overcharging - Printable Version
+--- Thread: Overcharging (/showthread.php?tid=557)
Pages: 1 2 3
Overcharging - Hibbing_Coronet_500 - 03-14-13
Yes! And Yes!
No need to re invent the wheel or re wire the car.
Hope it helps your situation. And from there you can rule out volt drop as a suspect..
Good luck.
Keep us posted
Overcharging - 383bee - 03-14-13
Hibbing_Coronet_500 Wrote:Yes! And Yes!
Good luck.
Keep us posted
Thanks! Let you know what happens when I wire it up this weekend
Overcharging - Hibbing_Coronet_500 - 03-15-13
Here is a hand drawn sketch of what I did to my 67. I re wired it because the under hood wires were stiff and crispy. I had to put the new VR and ignition system on a Relay due to voltage drop thru the bulkhead. My old VR was not affected by the voltage drop because I was running on one field, other field went to ground with the old style VR.
1177
Also forgot to mention that I ran another wire from the alt to battery down under the radiator core support and back up to the battery. I had installed a fused junction block near the battery to power my headlights that I also put on relays as well. But thats another episode...
Overcharging - 383bee - 03-16-13
Update.problem solved!the relay took care of The voltage drop causing my overcharging.i want to thank all who chipped in to help me solve this.in particular joe ( Hibbing) the schematic really helped.now I can drive the old beast without worrying about the elec system (for now).i hope I can help someone else.david
