New bullet for the "Brick" - Printable Version +- DodgeCoronet.com (https://dodgecoronet.com/forum) +-- Forum: Tech Discussion (https://dodgecoronet.com/forum/forumdisplay.php?fid=4) +--- Forum: Coronet Restoration/Paint Shop/Body Shop (https://dodgecoronet.com/forum/forumdisplay.php?fid=17) +--- Thread: New bullet for the "Brick" (/showthread.php?tid=3681) |
New bullet for the "Brick" - theman440 - 03-08-22
New bullet for the "Brick" - 67r/t4speeder - 03-09-22 You found a wheel? Or restored original. Looks great New bullet for the "Brick" - theman440 - 03-10-22 It is restored, a guy named Charlie Quarters did it. He's in Michigan. New bullet for the "Brick" - markz - 03-10-22 theman440 Wrote:It is restored, a guy named Charlie Quarters did it. He's in Michigan. Awesome! I like Charlie. He sold me a NOS horn ring for my 65 Fury. Good price - very hard to find. New bullet for the "Brick" - theman440 - 03-10-22 He offered me a restored 3-spoke wood grain for my convertible for $500, a little too rich for me. The one for the racecar was $300!, he also offered me a nice horn ring for mine (racecar) for I think $100, but my original is really nice. New bullet for the "Brick" - 67440Dodge - 03-12-22 Wow.. and back in the day some Canadian guy paid me $300 plus shipping for a cracked red 66 just cause the chrome center was mint on it. And he set the price, not me! New bullet for the "Brick" - theman440 - 03-13-22 Wheel polishing time, gotta look good for MATS. 12366 New bullet for the "Brick" - theman440 - 04-08-22 Back at the Track! Here I was checking the timing and checking the rotor phasing, it was perfect! then installing a new cap & rotor. 12403 New bullet for the "Brick" - theman440 - 04-08-22 Report - The weekend was a bust, I only got 2 passes in and folded it up, too many issues. The plan was just to make a few easy 1/8th mile shakedown passes to check all the "systems" first and go from there. 1. The driving was bad, it's been 5 years and I'm not used to how quickly things happen in 10 seconds 2. My "revolutionary" Pan-evac/breather box system is a bust - pulled oil out of the engine and made a huge smoke screen on the first pass, had to shut it down and get towed off the track. Looks like I'm gonna have to put the breathers in the valve covers. Gonna have to drill holes and have some baffles welded into the inside of the v/covers. 3. Engine has an oil leak in the rear. 4. For the second pass I pulled the pan-evac hoses off the check valves, re-routed them up to the hood hinge area (both sides) and taped rags over the ends of the hoses. Made another half pass and when I got back to the pit and pulled the hood some residual oil had soaked the rags and made a mess. 5. Rt front tire was leaking Some positives - 1. Car went 1.42 60ft (3675 lbs on 9inch wide old, hard, worn-out tires. If I can't get it into the 1.30's I'll be disappointed. 2. Went 6.50 in 1/8th (not even sure if it was a full 1/8th mile pass and don't even know where I shifted it) 3. Even with a filled block the cooling system worked great, gauge stays at 180 degrees (I may have to go to a 195 degree t-stat and fan switch) 4. Brakes seem to work good. I have started pulling the engine again to address the problems. |
