Does anyone know of an electronic ignition that doesn't look like one? - Printable Version +- DodgeCoronet.com (https://dodgecoronet.com/forum) +-- Forum: Where The Fun Happens (https://dodgecoronet.com/forum/forumdisplay.php?fid=3) +--- Forum: General Discussion (https://dodgecoronet.com/forum/forumdisplay.php?fid=12) +--- Thread: Does anyone know of an electronic ignition that doesn't look like one? (/showthread.php?tid=3031) Pages:
1
2
Does anyone know of an electronic ignition that doesn't look like one? - harold prentice - 02-23-16 I'm with tekhouse - bridged the back of my Ballast with 12ga wire and even keep a "spare" resistor in the glove box in case anyone suspects I've changed anything! Also bought the "black" ignitor coil and stripped the decal from it - looks stock. Finally, I added the optional power relay to feed the coil just in case - a sharp eye might see it! Pertronix works great. Does anyone know of an electronic ignition that doesn't look like one? - Sedanman67 - 02-24-16 http://www.designed2drive.com/ This lets you mount a GM HEI module on the bottom of your Mopar distributor. Very little wiring and no holes. Does anyone know of an electronic ignition that doesn't look like one? - TekHousE - 02-24-16 Good point about the coil. I also got the ignitor III, I will take mine off and strip the decal too! harold prentice Wrote:I'm with tekhouse - bridged the back of my Ballast with 12ga wire and even keep a "spare" resistor in the glove box in case anyone suspects I've changed anything! Also bought the "black" ignitor coil and stripped the decal from it - looks stock. Finally, I added the optional power relay to feed the coil just in case - a sharp eye might see it! Pertronix works great. |
