engine leaning out at 5000rpm? - Printable Version
+--- Thread: engine leaning out at 5000rpm? (/showthread.php?tid=3006)
Pages: 1 2
engine leaning out at 5000rpm? - Jpr777 - 10-31-15
I see you have welded a bung in your tank,
Good idea
Yes dragnet standard valve springs with upgraded cam
engine leaning out at 5000rpm? - Drag-Net - 10-31-15
What is the fuel/air ratio at just before it starts to break up? Stock 440 six pack and Hemi cars run 3/8 fuel lines and mech. pumps over 5000 rpm's with no problem.
They have more carb. bowls to keep full then a single four bbl. I would up grade the valve springs to the recommend ones the cam requires before getting to crazy with the fuel system.
engine leaning out at 5000rpm? - markz - 10-31-15
Jpr777 Wrote:I see you have welded a bung in your tank,
Good idea
Not exactly a bung -its a 5/8" pickup at the back of the tank............
7404]7405]7406]7407]
