05-28-13, 03:16 PM
Over the weekend I dropped my gas tank to replace sending unit and replace fuel filler and vent hoses.
I pulled the sending unit. And bench tested it. Empty 68 ohms. Slowly moving the float to full. The ohms went lower and lower then jumped to 85 ohms and at full position it was "open".
Okay.
Sending unit is junk. I tested the new one. Empty 73 ohms. Full 11 ohms. Smooth numbers while moving the float.
I have a old B body tank. I cut a 4 inch hole in the tank. I installed the old sending unit to see if there could be any adjustability in the float arm to tune it if needed?
A visual inspection. It is obvious that its a fool proof float setup. You can't even install the sending unit upside down by accident!
Now I have to weld up my old tank.
Okay.. tank went back in with all new items. I re tested the sending unit empty with it in the car and grounded!
73 ohms. Perfect!
Lower the car. I put in exactly 10 gallons of gas. (Half tank)
Start the car.
Fuel gauge says 1/4 tank.
The old sending unit with 10 gallons would register empty.
I have some improvement. I plan on running a new wire from terminal "C" to the sending unit.
I also have a new mother board with the intergrated voltage limiter.
What have I missed?
Thanks again
Joe
Okay.
73 ohms. Perfect!
Start the car.
What have I missed?
Thanks again
Joe
![[Image: fuel%20gauge%20diag%202.jpg]](http://www.austin7.org/Technical%20Articles/Fuel%20Gauge%20Working/fuel%20gauge%20diag%202.jpg)
